Blurred engraving on left side of 1290 bed.
lemontreehouse
Post by lemontreehouse »
hi
I have a ls1290 and 80w tube. recently I have noticed that the further the head is to the left of the bed, the worse the engraving. I did a row of ten invites for someone with some pretty fine fonts used. on the right side the writing was fine and crisp but on the left it was almost unreadable. I had to throw the 4 invites furthest to the left. I have cleaned the mirrors on the arm and head and made sure they are aligned but its still the same. the lens has also been cleaned. I fired the laser with the head at the far right and it left a tiny fine dot in the ply, when I do this at the far left, the dot is twice the size. have you any ideas please.
jon :(
Re: Blurred engraving on left side of 1290 bed.
Hi Jon
Is the bed level
If you focus the laser at the left is it the same focus on the right
lemontreehouse
Thanks Tom
I had just put a large sheet of ply on the bed and thought I would try each corner with a fire of the laser. I started in the near right corner and set the bed to the focusing square and fired a shot. this gave a fine pin prick. I then went to the near left and fired it and it was a bigger hole in the ply. when i went to the far left i noticed the red dot had moved away from its normal position. when i checked the focusing square, it was about 6mm higher. i lifted the bed and found a small piece of 6mm ply was sat on the left runner.
Now all sorted.
phew. thanks again tom for your spot on advice
jon :oops:
It's amazing how they sneak under isn't it :lol:
I have levelling bolts on my 1290! Added using 6 techlok screws . . . .
