2D Design and LaserCut5.3
keithwright
Post by keithwright »
We have noticed that if the file created in 2D has been altered a number of times i.e. lines etc added then deleted problems occur. The created DXF file when taken into LaserCut5.3 can have large parts missing. If I redraw the image in the file in a NEW file this usually gets rid of the problem. I noticed that someone else had had this problem with other software hope this will help if you have had this problem.
Keith
Re: 2D Design and LaserCut5.3
There are quite a few problems with some cad packages Keith, 2D Design being one of them, I tend to stick to either AutoCAD or Draftsite as they both have licensed compression for the DXF format.
endcan
Post by endcan »
We tried this one before and found of you export in plt format from 2D design
This solves it as some of the fonts are not exported when you send as a dxf
Hope this helps it did for us!
