tube in cold weather
dreamcatcher
Post by dreamcatcher »
I have a LS3020 and this is our first experience of having it in very cold weather. We have it outside in a shed and I'm worried about the water freezing in the tube. Is it ok to put anti freeze in the water or is that a bad idea?
Any advice very welcome. Thanks in advance. :)
Re: tube in cold weather
HPC sell anti freeze that is suitable.
Keeping the pump running will also help as the pump will heat the water a bit.
dreamcatcher
Thank you Dave. It's good to have an expert around. We'll order from HPC in the morning. In the meantime will keep the pump running.
Thank you :)
Not sure about expert - whats the saying... ex is something that has ceased to be and a spurt is a drip under pressure! :D
tilltots
Post by tilltots »
Mine's in a shed and the hpc anti-freeze worked a treat in the tub, I had previously lost a tube to freezing water. Since upgraded to one of the files and I put a bit of anti freeze in the water in that and I've had no issues and have been running it like that for a few months now.
LS3060 with a 60W upgrade
Users browsing this forum: No registered users and 23 guests
