Machine Will not move on X Or Y axis
I just got back from HPC after having new bulb fitted 3040
Plugged it all back in and re loaded software and Laser firing on test laser I can also see the downloaded file on the machine but the heads on Y and X axis are not moving at all. nothing happens on test
If you press Run the clock times and it beeps for finish but no movement on the head
Help please if you can
Steve
Steve
Re: Machine Will not move on X Or Y axis
Anyone???
What state is it? Does it move in manuAl mode?
No it will not move using up down arrows on the machine
You can move the head up and down and side to side with your hand
There are 2 black boxes inside with a Cat 5 sockets and a green and Red light on each unit. If I remember the green light used to be on. but no lights are on.
Are there any fuses anywhere that could have blown?
Check the emergency stop button has not been pushed in - if it's not that call HPC.
Stop button OK
Yep another 11 hour drive by the look of it
Yeah - sorry I re-read your message. It does sound like a loose/disconnected wire possibly bumped loose in the car. HPC may be able to take you through it over the phone?
Ive noticed that the 2 X Leadshine DM422 stepper motor drivers have a green and red light and am sure that the green light used to be on, but no lights are on both units. There is a cat 5/telephone socket on is it possible I need to download Software/Firmware or something?
