Help needed please
Re: Help needed please
Can you post up the file? saving it as DXF is possible in Corel, but it has to be drawn as 0 width lines (or as small as possible I think). Not quite sure how.
Can also be traced Phil from bitmap in corel but in Sue's case I'd avoid going there.Too many variables and settings that need to be changed unless your pretty good with cad file generation in general.
I wont be offended at all by the last post Lol.. I wish i had taken those TD leasons now when I trained to be a Graphic Designer! just to let you all know - & I know you must be wondering
someone told me I had the laser turned down to the very lowest setting so it wasnt doing any cutting - did anyone on here tell me that? They proberly did! - I thought it was all done on the computer. Oh well ive been cutting and engraving like a mad woman!
Thanks for all your help
Sue
Sue
good to hear Susie
No on the 3020 only the speed can be controlled - keep the power as low as you can for the time you want to spend cutting and keep an eye on the water temp, both will help make the tube last longerSusie wrote: I thought it was all done on the computer. Oh well ive been cutting and engraving like a mad woman!
Sue
Enjoy the wonderful albeit a steep learning curve of owning a laser
Hi There
Can anyone give me an idea where I can buy 2-3mm wood from mapel/walnut/beech/ anything like that. I have tried the 2 you told me about but they are a little slow to get back to me & really could do with some now.
Susie
Susie
http://www.cornwallmodelboats.co.uk/aca ... sheet.html
http://www.woodveneeruk.co.uk/products.php?cat=8&pg=4
Hi Therer
I am trying to make some boxes from light card 160gsm. I have the cutting out setting ok but would like to lightly score the card so that it folds easily, I am finding that it is taking a hour to score and cut out just one a4 sheet of card. Can anyone one tell me how I can speed it up please1
Susie
Susie
Meant to say its the scoring part thats taking forever and a day.
I assume you are engraving the scoring? If so there is not a lot you can do - best way would to either have a second file with the score lines and cut but on a much lighter setting or try to engrave just horizontal lines. I guess you could then change the head direction and then engrave vertical only on yet another file but you are on your own there
