Looking for some advise from users on the forum.
I am in the process of trying to pick a Laserscript lasercutter.
Initially I want to be cutting detail designs with very fine detail engraving.
Small detail will be down to 1mm.
Material will be 1mm limewood.
I have looked at the spec of 3020 pro with lasercut software or 3050 or 3060 machines and only 3020 seems to do small detail 1mm-1mm.
Should I go for 3020 or does anyone think larger machines will still give fine detail.
Many thanks.
Hello from Lanarkshire
Re: Hello from Lanarkshire
Hiya,
The bigger machines have better laser heads and can give finer resolution. The problem with small details is using too much power, wood has a specific heat value and once you get over this it can char or burn if the cross section is too thin.
Hi - welcome
Certainly no difference between the 3020 and 3060 detail wise but would recommend you get the lasercut version if you do go for the 3020.
many thanks for answers,
Choice now down to 3050 or 3060
Next silly question-
Except from bed size - cutting area, Is there any other differences between the 3050 and 3060
thanks
thanks
Not a lot from what I can see - apart from being a desktop! I would check to see what size your most used material comes in which may help decide on table size. I find the 3060 is quite handy as quite a few suppliers do sheets 300x600 so less cutting to fit the table.
3060 has wheels so can be easily moved (to check tube etc.) but a desk on wheels for the 3050 is just as good.
May be worth checking with HPC if the 3050 could be upgraded to a 60w if required. The 3060 can but if all you are doing is light engraving this won't be an issue anyway but could be handy in the future.
Users browsing this forum: No registered users and 18 guests
