Engraving aluminium
Highlander
Engraving aluminium
Problem trying to engrave what i think are aluminium tools.
No matter how slow i run it or how many times i run the program it hardly marks the surface.
I've been engraving other tools no problem.
Any ideas?
Any ideas?
Re: Engraving aluminium
What machine, power etc?
Highlander
6040
tried Speed right down to 20
Power 100
60w tube
had scan gap right down to 0.001
run program multiple times
all other tool types engraving fine
Power 100
60w tube
Unless the aluminium is anodised or treated with cermark type fluid it won't engrave metal.
Were the other tools coated?
Highlander
Other tools are all hardened steel.
am i easier having them milled?
I was worried the laser would melt them to start with but i can hardly mark them
Can you show pictures of the hardened steel?
Normally these power CO2 lasers will not mark metal without the magic liquid.
I have a fibre laser that marks metal - but if you need a deep engrave then milling may be easier for you
Highlander
Mostly pliers, spanners, hammers etc
we've been using it to mark tools for a few years now, only real problem we have is Channelock Pliers that need doing 2 or 3 times
Cool - will have to play
Highlander
these are done at the following :
Speed 20
Power 100
Scan Gap 0.01
Speed 20
Power 100
Scan Gap 0.01
Thanks - I suspect it is a heat treatment more than actual ablating but cool nonetheless
