LS3020 LSCT - Startup issue
sam
Post by sam »
I have an issue with my LS3020 LSCT when powering the machine on, it doesn't want to reset to the top right but keeps trying to go right and it jumps left to right?. I see a little trigger switch down there, and I wonder if that's the problem?.
The machine itself cuts fine when I pick a new datum spot to begin from, it's that initial power up 'reset' the machine has the issue.
I've linked a video below:
https://youtu.be/tMw8Lq4dv44
thanks for your help.
Re: LS3020 LSCT - Startup issue
I would guess that the switch as moved a bit so the head is hitting the gantry before the switch makes contact. Make sure the switch is being held tight , if not move it to the left a bit and tighten it up ;)
sam
Post by sam »
Hi Daven,
It does look like the arm on the microswitch isn't correctly pressing against the button on the switch. I could do with seeing what shape the arm should be so I can get it back working correctly.
I know you probably have a larger machine than mine, but might it use the same switch?. A photo could be handy if you could get one your end?.
(I've asked HPC for switch info also, so I can see how it should sit).
Sam
My 3060's are a bit different but the arm is straight and is at an angle about 5mm out from the end. You can bend the arm out a bit more if there is no adjustment on the switch.
sam
Post by sam »
I managed to fix the issue. I guess I caught the arm on the microswitch when removing materials at some point so it had bent slightly out of shape, so I gave it a tweak back to how it should be and the issue is all gone.
Thanks again for the help.
Well done ;)
