Having a bit of an issue finding out anything about this. Does anyone know if polyurethane casting resin (once poured and cast) can be laser engraved?.
I guess it's more of a case of it giving off potentially nasty gases, as the engraving itself would technically work.
Sam
Can resin be engraved?
Re: Can resin be engraved?
"Dust from sanding and cutting finished polyurethane may cause skin and respiratory problems due to the presence of unreacted chemicals from the curing process."
See http://www.nontoxichub.com/plasticssafetyoverview
