Carplan De-Ionised Water 2.5L
izzysdaddy
I was in Tesco's today & Carplan De-Ionised Water 2.5L was on offer. Normal price was £1.15 but reduced to £0.55 till 1st March.
Regards Stuart
Regards Stuart
owner of a LS1290
izzysdaddy
Re: Carplan De-Ionised Water 2.5L
Went into a smaller Tesco store today & they did not sell the water. The store I saw the offer in was one of the large ones (Cheshunt Brookfield Farm). Just checked Tesco.com website & still on offer, so if wish order on line with your home shopping.
Stuart
Stuart
owner of a LS1290
llamalasers
Thank you, will stock up
60W LS6840 & CW4000
started out with LS3040
SillyJokes
I just use tap water.
Do I really need to use distilled water, whats the advantage?
Owner of a new LS3040 PRO
Tap water is more conductive and contains minerals which may build up inside the tube.
SillyJokes
Daven wrote:Tap water is more conductive and contains minerals which may build up inside the tube.
I don't see any build up in my tube, perhaps my tap water is soft enough.
The conductive thing, is there any conducting going on in the water? or is that a safety issue?
I can't officially answer that as I am not qualified - the water does not come into contact with the electrodes unless something goes wrong - that's the time it matters and I play on the safe side.
Eurocarpart are selling it for £2.29 for 5ltrs at the moment http://www.eurocarparts.com/deionised-water is it worth taking the risk?
I had a tube which I had a build up of scum in the output coupler which reduced the flow until it over heated the tube. I could not shift the scum as you can't get into the coupler to clean. I suspect it was due to using too much Milton (I know use chlorine).
SillyJokes
Daven wrote:I can't officially answer that as I am not qualified - the water does not come into contact with the electrodes unless something goes wrong - that's the time it matters and I play on the safe side.
Point taken.
But, surely if you then put Milton tablets or chlorine in, it becomes all conductive again. (I use Milton)
izzysdaddy
Sainsbury's sell a 2.5lt bottle for £1.00. Only the stores which have a small diy section (can be found in car maintenance section). In the store only not the petrol station.
Stuart
Stuart
owner of a LS1290
Again I'm not qualified so check the results for yourself but Chlorine has relative electrical conductivity of 0 0.01 S/m (AI=1) and is classed as an insulator, apparently - no idea about Milton - if it contains salts the yes it will affect the conductivitySillyJokes wrote:[
Thanks Stuart - I don't have a Sainsburys that close so normally get it from local garage (or the links above)
