Hello,
Has anyone out there been using Mirror Perspex, if you have, what sort of results have you had and what settings have you used to cut and etch.
Thanks in advance for any replies.
Dynamode
Mirror Perspex
Re: Mirror Perspex
I do - cuts about the same as normal Perspex so around 20mm/s at 70% on a 60w. Etch depends how deep you want but 200 at 30% 300dpi would be a good place to start
Re: Mirror Perspex
What thickness is that for Dave ?
Re: Mirror Perspex
3mm
Re: Mirror Perspex
Ta
I've not cut much plastic as I don't like the smell .. like , you can smell it for miles !
I have some Mirror stuff, think its thinner than that. .. been a while since I cut any though
Re: Mirror Perspex
Good results with 3mm acrylic here.
