Cutting small intricate parts I found laser would make two or more 'passes' on some lines making them wider or even burning through thin parts completely. Also takes longer to cut job with extra laser time used.
I use CorelDraw to design. Checked these files and found the obvious! When, say, you draw two rectangles and bring them together side-by-side where they join there are two lines! Laser cuts these twice. This can happen with other shapes too. Solution is to ensure you delete one of the joint lines before saving file and sending to NewlyDraw and laser. Also make sure you have lines set to 'HAIRLINE' width when drawing or laser can make two, three or more passes.
BobG
Ensuring only cut lines once
Re: Ensuring only cut lines once
Good tip Bob, Thanks
Hiya Bob,
All cad packages do
even the mighty AutoCAD (Read: bloody expensive autoCAD) will do the same,
There are two objects hence the machine will cut two objects even if they are on top of each other. Where possible draw a single box shape and on another layer draw the cut line that separates them (Turns it into two items). If the outer line is a PolyLine and the cut line a single it will run efficiently with minimal cut moves.
It can be annoying though, hunting through a drawing with no easy quick way of finding double entries on the same layer
All cad packages do
