Drivers
uklasermonkey
Drivers
Hi everyone, my first post here. I've had a HPC for two years and just got a new laptop. Unfortunately the laptop does not have a disc drive. I have installed laserscript 5.3 but I have no drivers to connect my laser. Are these available electronically as I've looked but had no joy?
uklasermonkey
Re: Drivers
I have a LS6840 if that makes any difference?
Re: Drivers
Will PM you in a while.
I can't help with the laser machine settings but you could copy that from the old PC if you can.
uklasermonkey
Re: Drivers
Unfortunately said pc is refusing to play ball. Keeps blue screening on boot up
Re: Drivers
Ouch - you could possibly take the hard drive out and connect it as a non bootable additional drive and try to access if via file manager. If it is just the systems file that are corrupt the rest of the file structure could be ok.
uklasermonkey
Re: Drivers
So I tried the drivers files I was sent and nothing. The device (laser) is now showing as EZ USB FX2 however there are no drivers present when I try to locate them where I saved them on my pc and the 'browse online' option is coming up empty.
Re: Drivers
Browse offline to the folder where you stored the files
Where did you get the LaserCut program?
uklasermonkey
Re: Drivers
Thanks Dave. All sorted now. Managed to source a disk drive and ripped the installation files off the disc, copied them over to my laptop and completed the installation.
Back up and running and just in time as I've just received an order
Re: Drivers
Well done
