I'm not having the best of luck with my LS3040
I've contacted HPC and an engineer is due to call me tomorrow but I'm impatient as want to get lasering, so hope you can help.
1. The z-bed is jammed! Originally, it looked like the tiny screws on the internal shafts were not tight enough. Tightening them up seemed to periodically fix the problem but now the bed is not moving at all. I used to be able to manually turn the second shaft (running vertically) and the bed would move, but now nothing. The belt doesn't move at all, which means no lasering anything as the height is not correct
2. The red guide beam works on the right hand side of the bed but when the head moves across the centre, it cuts out. I’ve been told it could be a loose wire but can’t find the problem.
Any advise would be appreciated.
Thank you.
Kim
