Importing with exact size
ednotdave
Post by ednotdave »
I'm guessing there's a really obvious answer to this, but I just can't see it!
How can I import an image into Lasercut without the dimensions changing? Let's say a simple 25mm x 50mm rectangle - when drawn at that size in AI or Inkscape, then exported as a png, bmp, dxf, always ends up a different size when imported into LC. I know I can draw the shape the correct size in LC, but surely there's an easy way to do this? Is it something to do with resolution?
Newbie attempting to use a LS3060 60W + CW4000 + Lasercut 5.3 :shock:
Re: Importing with exact size
Sounds like you have some sort of scaling, or inches>mm issue.
What size does a 100mm square arrive into Lasercut?
ednotdave
Post by ednotdave »
Hi PD
I've tried all sorts of combos - all different sizes, but none as they should be!
Lightnin
Post by Lightnin »
what software are you using to design in ?
Check the 'unit's of the software you use to design - they should match Lasercut as in MM.
Some software uses a unit - that unit can be cm, mm, inches, pt, pixel....
In Inkscape - look at 'Document properties' for example and have a play with the settings to see if that helps.
To be honest I tend to re-scale in LC rather than edit the image ;)
ednotdave
Post by ednotdave »
Yep, everything is set to mm.
ednotdave wrote:Hi PD
Trying to find out the error first. What size is it in lc when imported :)
TimBobTastic
Post by TimBobTastic »
Not sure if this helps but...
With inkcape, when you export the dxf file make sure the export units are mm and not pixels or inches... this bit me a few times before I realised....
