Laser Tube
smilerpete
Laser Tube
Post by smilerpete »
Another problem has occurred, I have been cutting 3 mm plywood and suddenly it will not cut through even on full power and low speed.
When I aligned the mirrors and tested the tube to see if it was firing central and leaving a hole, it now is firing and leaving 4 holes in a circle, I have cleaned each mirror and the one in the end of the tube but still no joy.
Could this be a blown tube, I have had the tube 2 years.
Thank you
Pete
Re: Laser Tube
smilerpete wrote: it now is firing and leaving 4 holes in a circle
At what point - on material on the bed or between mirrors? What pattern do you get on the entry hole in the head?
smilerpete
Re: Laser Tube
Hi Dave
Thanks for your reply.
The pattern I get is like a 3mm circle with around 4 dots cut out.
The pattern I get at the end of the tube is like a C shape.
Pete
Re: Laser Tube
Post by Tom »
Hi Pete
I think Its time for a new tube :(
But it will probably sort your other problem :)
smilerpete
Re: Laser Tube
Hi Tom
I think your right.
Users browsing this forum: No registered users and 19 guests
