Laser bed isn't level?
Chris
Post by Chris »
Hiya ive noticed that my laserbed isnt level - its about 2mm lower at the front than it is at the back and as a result the laser becomes lass focused when it cuts towards the front of the machine. is it easy to adjust it?
Re: Laser bed isn't level?
I would just shim it up where required. I drilled and tapped levelling bolts in my ls1290s to get it level. While my original ls3020 was just some stickers piled on top for the honeycomb bed!
Chris
Post by Chris »
yeah that's what i've done but just wondered if there was an official way to align it
Unless you fancy getting underneath, stripping down the table, height adjusters, removing belts, adjusting every corner, then putting it all back together again, I wouldn't. I have done it on my LS6840, and to be honest, it was not worth the nightmare. It was much easier to drill and tap the bigger one :)
Chris
Post by Chris »
PhillyDee wrote:Unless you fancy getting underneath, stripping down the table, height adjusters, removing belts, adjusting every corner, then putting it all back together again, I wouldn't. I have done it on my LS6840, and to be honest, it was not worth the nightmare. It was much easier to drill and tap the bigger one :)
fair enough lol ill stick with my wedges
keithwright
Post by keithwright »
The 6840 bed can be levelled fairly easily. Check for the inaccuracy you need to adjust. Disconnect power. Open front centre door to belt drive. The bed drive screws are connected to the drive chain by Hex screws. These need to be undone and the screw adjusted. The screw is greased so wear plastic gloves. retighten screws and check.
KeithWright
davehills
Post by davehills »
Just followed the advice of "keithwright" and the job took about fifteen minutes. Probably quicker that making (and losing) shims or drilling/tapping the corners to add screws.
Only time will tell if it'll creep out of alignment over time.
From memory the screws have flats on them for the grub screws, clamping off of the flat will work loose quite quickly :(
davehills
Post by davehills »
I'll keep my eye on that. I didn't notice any screws not screwing in as far, but time will tell.
BenH
Post by BenH »
I've noticed a similar problem with my LS3060, would the following solution work on this model?
Cheers in advance
Users browsing this forum: No registered users and 173 guests
