Hiya,
A quick first thought is side scatter looking at the picture, as the final slideway moves left and right if the beam is not striking the mirror in the middle the exit angle will change (hence cut angle will change).
My first recomendation would be to adjust the mirrors (starting at the second mirror) right the way through to the final exit mirror. It's very rare that the initial mirror (the one the beam hits first) goes out of line so I wouldn't be moving that one about. The closer to dead center you can get it the better, it can be the difference between cutting 5mm plastic and 8mm plastic in one hit.
Experience so far has taught me that laser exit angle is quite critical to a good cut and low power requirements.
Give that a go and let us know if there is any improvement or not
Chris or Charli may know more and their after sales support is fantastic
