USB stick file rules.
steveastrouk
What are the rules for files placed on a USB stick ? Is there a maximum size for the USB stick ? Can the machine navigate directory structures ?
What's the working file ? A .MOL ?
Steve
Steve
Re: USB stick file rules.
Steve,
A decent quality stick with a basic format works best, DON'T use these sticks that have virtual CD roms etc...it will just cause problems.
When importing or openning you can navigate the full directory structure (within the confines of the windows character limitations) from the stick.
.MOL is the run file, it and it partner files contain the co-ordinates and the speed / power settings.
When running an MOL select "Open" from the file menu NOT "IMPORT"
"Import" is used to generate the first run from your DXF file.
hope that helps a bit
rgrds
rgrds
steveastrouk
I have a clean, fat32 stick, newly formatted under XP, so about as basic as it can be, it has two files "test" and "test2" as .mol and .txt files.
When I plug it in the laser, the device reads it, and then gives me the only option "read ALL" - press Enter, it reads the stick, then says remove - but I see no new files in the on-board file list.
Out of interest, have you any idea what the data structure of the .mol file is ? I can see the .txt contains something looking like HPGL or G codes, but the .mol isn't ASCII codes
Steve
Steve
Not sure to be honest Steve, I'll haver a look at one this afternoon and see what I can come up with.
Do you go direct into the Laser from the stick (via the usb port) or are you loading from a PC?
steveastrouk
Hi Dave,
For reasons best known to my main laptop, it wouldn't accept the USB drivers for the laser, so I was doing the prepararation off-line, and loading VIA the USB stick port.
Steve
Steve
Hiya Steve,
I have no experience of loading direct via the port
drop Chris or Charli a line I'm sure they will have an answer
steveastrouk
Thanks Dave,
I'll ring Chris on Monday.
Steve
Steve
steveastrouk
The answer seems to be that the stick MUST be <<1Gigabyte - the machine freaks out with anything bigger. Problem these days is FINDING sticks <<1 Gig !
Steve
Steve
Steve,
Tesco!! 1 gig sticks £2.99
steveastrouk
Not sure what Si used, like I said, I have a feeling it was a lot less than 1 gig.
Will try a Tesco one tonight though....
Steve
Steve
