Convert images to DXF
Not tried it as I use R2V but just found this. There is a free trial that you can dowload - if I get a chance later I will try it an compare to R2V.
Re: Convert images to DXF
Had a chance to try this software today - not bad but not quite as good as R2V. The main difference is R2V allows you to preview the image and the results before saving. The trial version allows you to save a file in DXF, EMF, WMF, HPGL or text.
It will handle multiple files, unlike R2V but the trial version only allows you to save 3 files at a time.
