Cleaning and Cutting Vectors
DavidJHolmes
Re: Cleaning and Cutting Vectors
Post by DavidJHolmes »
I'll have a look and play. I like Illustrator as I can import raster images and then draw them to vectors for my plotter. Just tried to import one to AutoCAD and the results weren't good! :( So now downloading AutoCAD Raster Design to try.
A program called R2V is quite good and not too expensive for quick converting from Raster to Vector, a bit of tidying up in draftsight maybe depending on the quality of the original! You can download a trail version from their site http://www.mr-soft.net/
Spooky wrote: Also a box from right to left (green) will highlight everything it crosses and box from left to right (blue) will highlight everything it contains.
Omg, I never knew that! That explains why it only sometimes highlights things I tell it to! How the hell could I have missed that one :oops:
Even on a closed polyline Phil, highlighting using a green box will allow stretch at the crossing points without exploding it first. There are quite a few undocumented features of AutoCAD that autodesk don't publish or support but put them in anyways.
Quite a few are in the far right main toolbar under "Express" such as align text to curve etc :) well worth playing with :)
DavidJHolmes
On the Lasercut info on the HPC website under 6840, it says direct output of AI files. Also direct output from Corel. Unfortuantely I don't have Corel on my windows 7 PC, on which I do most of my work. I have it on my XP laptop but its too hard to use on a laptop. Anyone have an experience of using AI files and how well did they come out?
DavidJHolmes
Although I've just looked and I'm entitled to 80% of Corel if it was worth it.
It's a bit of a pain David but go for an older version of AutoCAD, Ebay is usually good and you can pick up a 2000 - 2003 version for under 30 quid.
I can't help with AI files, I never use them :(
ps: Youtube has some very good basic tutorials for AutoCAD posted.
DavidJHolmes
How does the licensing work on the older boxes? The 2012 version has to be activated online and registers the product to your address! I can buy a perpetual licence for £70 for the 2012 version for unlimited usuage but it prints "STUDENT EDITION" around the edges or words to that affect. It doesn't bother me, I'm not doing commercial work with it.
The earlier versions just run off of a key, it calls home to ensure your not installing it on multiple boxes (although you can install them you just cant run them all at the same time)
Student licenses have some limitations, I can't really comment on them though as I only have experience of the full commercial licences :( I do know AutoDESK's definition of "student use" is a little skewed though..it doesn't quite tally up with most other software houses ideas ;)
