Engraving acrylic
Engraving acrylic
Hi guys
I there a way of stopping those white marks around the edge of engraved and cut acrylic. Some some of easy with iso but there are others which are hard to get off and i dont want to scratch the plastic.
Many thanks
Rich
Many thanks
Rich
Hps 6090 pro lasercut 5.3
Re: Engraving acrylic
Lower your airflow to the nozzle Rich, that haze is vaporised acrylic being re-deposited by the air jet.
Ahh ok. The pump I have is on constant. How do i change the air flow. Could i put a slight kink in the tube or will that knacker the pump
Cheers Dave
Rich
Cheers Dave
Rich
Awkward one Rich,
Restricting the flow may damage the pump,you can't stop the air all together or you will damage the lens. Lemme mull it over and see what I can come up with.
I was thinking of getting a bigger air pump and splitting the hose to blow in two directions. Could this work or would i run into problems
Could do Rich, main thing is to make sure you keep enough air going to surpress any flaming or much getting kicked back onto the lens
I was thinking about it last night and I dont think it would work. when cutting paper or card the material would blow around. Back to the drawing board.
Hi Dave
Been playing around with a few ideas and washing up liquid works brilliantly just like if you were doing glass. I just used a thin layer rubber in with my finger, engrave and wash off and just clean up with ipa.
The acrylic looks brilliant
Hope this helps anyone else
Cheers Rich
Cheers Rich
ive been having this issue also, so thanks for the tip!
keithwright
Try leaving the protective film on acrylic. This works for us but can be a little fiddly to remove on lettering etc. You may need to up power very slightly. I add 2.
Keith
DT Technician State secondary school
Keith
