Hi everyone, after a bit of help.
I have a problem trying to do a job on my LS3020LSCT. I can download a job to it, test it but when I press start the head moves about 2 inches left and half an inch down, then freezes. Nothing work then, the whole panel goes non operational.
When I turn it off then on again, it resets itself, then when I try to start a job it does the same thing.
I had this issue a month or so back, HPC sent a flash drive out to reboot the board in the the laser. This worked, trouble is it doesn't work now! So I don't know what to do.
I would call the office but I have so much on at the mo I'm not at home much. Any help would be appreciated.
I'm running a HP laptop with Win8.1. Had no problems to start with, after update to 8.1, she worked fine for a couple of days then 'kaput' as they say.
Unit 'freezes' when start is pressed
LS3020LSCT, Lasercut 5.3, Win7 netbook
a whole lot of time with only a modicum of talent
Re: Unit 'freezes' when start is pressed
Hiya Jim,
Have heard of this before but can't recall what the problem was (it was nothing serious from memory, although I may be miss-recalling it)
I'll go see if I can find out what the problem was in the other guys case. When problems get a little "iffy" like this sort of thing Chris really is the man to help, there are quite a few possibles but without being sure which one it is, it will be very hard to diagnose remotely for us here.
I have just had exactly the same thing happen. Help!
Mandy
Mandy
Ring HPC if you hav'nt already and ask Chris.
My wife as gone back too win8 from win8.1 has her pc started play up with 8.1
Update time!
Swapped to my old net book running win7. Downloaded the Configuration file from laserscript and....... it seems to be working again!
So I'll try for a little longer with this set up, I'll set the files up on my Win8.1 laptop and upload to a flash drive to send to my Win7 netbook.
So question time now. Is there an update to use Win8 ? It seems, initially, there is an instability problem with Win8.
Has anyone else had this issue, I know that when I got the machine the engineers who were setting everything up said they didn't have much/any experience with using Win8, serves me right for being too up to date with my laptop (there's a first time for everything lol).
