Using Illustrator to create the vector
Exporting DXF using EXDXF
Previewing Draftsite
Engraving with Newlydraw 1.5
Machine Laserscript 3020
I am relatively new to most of the above programs. I have been able to perfectly engrave and cut on my first 20 designs. However I recently made the following logo and even though its elements are larger and less intricate than many of my past designs, it seems to always engrave blurry.
There is no issue with the laser itself. In between multiple attempts I was able to engrave other designs perfectly.
In illustrator I have cleaned up the paths, expanded them etc.
I also exported to bmp and the problem persisted. I tried multiple materials. No difference.
Any help would be greatly appreciated.
Alan
Advice required: Engraving quality issue [Photos attached]
alanmccormack
- Attachments
- Blurred when engraved on any material
- (139.61 KiB) Downloaded 378 times
- Draft site preview also seems blurred
- (101.13 KiB) Downloaded 378 times
Re: Advice required: Engraving quality issue [Photos attache
Hi Alan,
If at all possible dump illustrator, it cause more problems than it solves
the compression algorythm used in illustrator isn't to the same standard as a dedicated cad program and the files can often end up losing information or details.
If possible design in Draftsite and go from there.
I'll go have a play with your picture in autocad and see what I can do
edit: just had a look Alan, the file is greyscale and won't convert properly direct to dxf,it will give an inconsistant edge (blurring)
If you want to mail me the full size version if there is one I'll convert / redraw it in autocad for you.
I tend to use JPG saved in black and white (2 bit) to engrave - Newlydraw has an 'enhance' option for engraving which can be useful as well.
alanmccormack
Spooky wrote:Hi Alan,
If at all possible dump illustrator, it cause more problems than it solvesthe compression algorythm used in illustrator isn't to the same standard as a dedicated cad program and the files can often end up losing information or details.
Dave: Thanks for the help. I have emailed you a larger file.
Alan
alanmccormack
Good to know Dave, thanks.Daven wrote:I tend to use JPG saved in black and white (2 bit) to engrave - Newlydraw has an 'enhance' option for engraving which can be useful as well.
Alan
All fixed
alanmccormack
You are a lifesaver Dave, thanks!
your welcome
get any more like it just drop me a line and ill help out
