Has anyone cut High Impact Polystyrene? I'm trying to cut sheets that have been vacuum formed and whilst it is working, it seems to be making a lot of fumes and a very bad smell. Is it ok to cut HIPs on a laser?
Sally
Cutting High Impact Polystyrene
nottinghamhigh
Re: Cutting High Impact Polystyrene
Hi Sally,
It's fine to cut it with a laser, it doesn't contain anything that gives of noxious gasses BUT it won't cut very well and will usually result in a rounded and discoloured edge as well as giving off quite a lot of black flecks of soot.
The Flecks won't do the machine a lot of good if they get sucked into your electrical cooling fans.
HIPS is best processed with routers or mechanical cutting such as CNC mills etc
To sum up? it's not dangerous but will look rubbish
nottinghamhigh
Thanks Dave,
It's for cases for the GCSE electronics projects. We were hoping it would save time, but I think that drilling will be quicker and easier to set up!
Thanks again
Sally
Thanks again
Sally
phil2simmons
Hi Sally
We use HIPS quite a lot at school and I concur with Dave's observation regarding the rounded edge which is also raised. Dont know why this happens though. The cut edge is also slightly ridged but this does make jointing (with Tensol or Dichloromethane) better when making an edge joint, or so I am told by teachers!
We use HIPS for a mobile phone holder project in conjunction with line benders and the laser cutting stick-on patterned shapes (downloaded from the net). The initial material is cut with a band saw though as this is really quick.
Phil
Phil
