Hello From London (and a bit of help)
OMT
Post by OMT »
Hello everyone, hope you're all safe and well :)
Got a question about engraving.
I'd like to engrave some text on acrylic. I'm using Autocad 2007 for the text and saving it as a dxf but when I import into Laserscript 6.1 all I'm getting is the text outline.
I've tried both hatching and polyline line width but neither seem to be working.
Thanks in advance
James
Re: Hello From London (and a bit of help)
If you set the object to engrave it should engrave as long is it is a single PLine - so 1st line turns on engrave next one in turns off and repeat.
If you are using normal annotate text I think you can Pexplode - it needs to be a joined polyline.
OMT
Post by OMT »
Thanks for the reply :)
I'll give it a go tomorrow and see what happens
James
