My bed on the software is the wrong size etc; how do you resize it ?
LaserCut 5.3
Re: LaserCut 5.3
file, Machine Options, worktable
JoshMilner
Re: LaserCut 5.3
Got that thank you, I still seem to be off the bed area etc is there set config files for each machine for Laser Cut 5.3.. I'm a complete noob and should be ok once the software is set up.
It's a older desktop style 3040 pro I've bought second hand.
Re: LaserCut 5.3
Hi - yes it should be part of the install disk - have you got it to transfer to the machine (if successful the machine will beep).
It may be worth calling HPC and getting the correct version for the card you have as well in case it is not the original disk.
Users browsing this forum: Semrush [Bot] and 17 guests
