A few days ago our LS6090 started leaving tags when cutting. If it is cutting a hole the end point doesn’t join to the start point. Has anyone else had this problem? It also seems to be moving from the start point. If I stop the machine and restart it moves a few millimeters down and to the left. Is there a belt that I need to tighten?
Any help would be much appreciated!
Sally
Alignment
nottinghamhigh
Re: Alignment
Hiya Sally,
At cursory first thoughts it does sound like belts or maybe a lose connection on a stepper servo...
Circles not meeting up at the start and finish is down to backlash (free play errors when the axis change direction) it's just a case of narrowing down what is causing that backlash.
Strange you should be getting this problem as I'm getting the exact same thing but I have a feeling it may be down to dirty belts more than lose belts as I've been cutting a lot of Medite and Birch ply of late....
Can I ask how clean is the inside of your machine? are the beds oiled on a regular basis? have you noticed any strange noises or whining from it?
nottinghamhigh
Re: Alignment
Hi Dave,
I've been using 3 in 1 oil on the runners and wiping down the cutting bed with IPA. I usually get the vac to remove any bits that have fallen through and any dust.
What do you use to clean the resin that birch ply leaves? IPA doesn't seem strong enough, so should I be using something else?
I'll give the machine a good oil and test it again.
Thanks for the help, it's so useful to be able to ask the experts!
Sally
Sally
Re: Alignment
Hiya Sally,
Laser Ply glue / resin is water based
Good soapy water will do it (but beware the usual water / electric / yadda yadda)
Have a gentle press on each of your belts and see if any of them seem more slack than others.They are adjustable but best not to move stuff unless there is a need.
(My late Father always told me, "don't fix that which is not broken")
nottinghamhigh
Re: Alignment
Hi Dave,
The oil hasn't worked, how do I check the belts and adjust and how do I clean them if I need to?
Sally
Sally
Re: Alignment
Hiya Sally,
It will likely be only one of the belts causing the problem. By pressing on each, one should be more slack than the others, if you can let me know which one I'll write the procedure down for tightening them (it varies from machine to machine and from axis to axis) all round an easy job though so nothing to worry about
