CW5000
Shaker21
CW5000
Post by Shaker21 »
60w Tube - CW5000
In the morning my water temps start at about 18c
Within 20 min its up to 35c and after an hour or so it touches 60c
If I leave it you can see the temps dropping and if I leave it an hour or 2 it will go back down to about 25c
Does the CW5000 need re filling with aircon fluid?
Re: CW5000
Sounds like something is wrong - if water is flowing and the air circulation is good (clean any air filters) then I would say it needs looking at - 60c is way to much for the tube so I would not use it.
Check the water is that hot going in as well in case it is the display/controls.
