Datum not moving
Datum not moving
The datum arm won't move on my laser. When I press esc to deselect the 'laser' file, none of the datum direction arrows work and neither does the z-axis.
I have reset but no luck.
Any ideas?
Any ideas?
Re: Datum not moving
It sounds like your not getting power too the stepper drivers
What machine do you have
It's the LS3060.
The arm moves freely when off and it will move when asked to do a datum re-set.
Thanks for your reply,
So it's just the arrow buttons? Does it move if you use the Lasercut ones?
Nope, it won't move with either the laser controls or laser cut. I have tried removing the pc still with no luck. The only way it will do any movement is if I press datum, which shows nothing is stopping it moving...
What is the stepper driver?
it's the electricery bit that is wired to the motors that move the axis around
It Can't be that if it will datum
Have you any other idea on what it may be? Or any suggestions for me to try? Thank you so much for your help
Best call HPC - if it is a loose wire or a component they will tell you how to fix it safely or suggest a visit.
We can't really advise you to mess about with the electrical side of the machine.
Users browsing this forum: Semrush [Bot] and 10 guests
