Problems with 2D Design
nottinghamhigh
Post by nottinghamhigh »
Does anyone use 2D Design with their laser cutter?
We keep getting a problem if anyone uses the dimension lines. When the file is exported into DXF format it either still has the measurements on it even if they have been deleted or the design is not complete, just a few of the lines.
Has anyone else had this trouble?
Re: Problems with 2D Design
Hiya,
Dimensions in most Cad packages get exploded and dis-associated, this can lead to problems when importing into your laser. Do you have a file you can post as a demonstration of the problem? it's a lot easier to help if I can *see* the problem rather than try to understand it (if that makes sense :))
What format DXF are you exporting to? It should be AutoCAD 2000 compatible.
nottinghamhigh
It won't let me post any attachments. It there another way?
Hiya ,
Just mail it direct :) Dave@opticalpower.co.uk
bob
Post by bob »
Hi Please try to do the dims in a different layer and colour and dont output them in lasercut this may work.
I have used 2d without any problems but not used dimension lines...
Hope this helps
Bob ;)
nottinghamhigh
Thanks for the help, it's great to be able to ask others advise!
Hope everyone has a good Christmas,
Sally
