Laser Bed not moving.
StJohnDT
Post by StJohnDT »
We have a LS6090, and last week during an inset for teachers the emergency stop button had been pressed. Since then, we are unable to lower or move the bed of the laser up or down. The machine is still cutting, but the red laser dot is also not present. Does anybody know how this problem can be rectified?
Any help would be appreciated.
Nathan
Re: Laser Bed not moving.
StJohnDT wrote:We have a LS6090, and last week during an inset for teachers the emergency stop button had been pressed. Since then, we are unable to lower or move the bed of the laser up or down. The machine is still cutting, but the red laser dot is also not present. Does anybody know how this problem can be rectified?
Nathan
Was it a small fire that made then press the Estop
StJohnDT
Post by StJohnDT »
I think so Tom, I was not present at the time.
Check the wiring on the red dot
And disconnect if melted
StJohnDT
Post by StJohnDT »
Thanks Tom,
I will check it today.
Any advice on the bed itself? Will rewiring allow this to be moved up and down?
Nathan
As it's in a school I think you are better of talking to HPC direct - HSE and all that ;)
Daven wrote:As it's in a school I think you are better of talking to HPC direct - HSE and all that ;)
DIY + School = TROUBLE!
Davo is spot on, get the experts in, fires in cabinets can cause all sorts of issues and the boys will know exactly what to look at and what is likely to have been damaged.
To be honest any advice other than call HPC is bad advice in this particular case (no matter how well intentioned)
The word was disconnect not rewire ;)
Tom wrote::)
Didn't mean you Tommy ;) your advice was good :)
It was for the op Dave (i should of quoted)
To the op
The two Dave's are right :)
This is a easy fix, give hpc a ring
