Colouring Engraving
ncamacho2000
Colouring Engraving
Post by ncamacho2000 »
Hi (6040)
Anyone got any advice on colouring/painting just engraved areas? I'm trying to engrave an image on glass (maybe perspex) and then somehow colour the engraved sections only. The image is quite fine and detailed so not sure if engraving through a laminate or surface first would work.
I was considering using something like a buff coloured wax that would stick to the engraving only and wipe off the glass. Anyone tried anything that works well?
Thanks - All advice welcome
Nigel
Re: Colouring Engraving
Hi Nigel,
There is a US product but I have not tried it or know of anyone who has yet. Acrylic paint can be used on acrylic but I doubt it would work on glass - what about glass paint?
ncamacho2000
Thanks Dave for the quick reply
Its a difficult one as i want something that wont stick to the ungraved (if that's a word) sections of glass but permanent to the engraved sections. I think Acrylic paint may work if i act quick to wipe on and wipe off. I will have a look at the US baked paint in your link.
Is there any descent film or liquid laminate that is really thin and easy to remove, wipe off after being lasered and sprayed?
Thanks again
Nigel
HPC do a liquid - have a look on the main shop site ;)
ncamacho2000
cheers dave will do
ncamacho2000
Hi Dave
Just had a quick look and they do the lasermask, have you tried it?? Can you wipe it off after?
Cheers Nige
I haven't but I seem to remember a post here from some one who has ;)
Will see if I can find it....
http://www.laserscript.co.uk/phpBB3/vie ... =lasermask ;)
ncamacho2000
right that sounds like just the job, ill buy some and see what happens
Cheers Dave - thanks for looking into it for me, really appreciate it.
Signchap
Post by Signchap »
The 'standard' way to fill engraving is to put a line of paint on the panel then squeegee it down across the engraving so it is pushed into the engraving. I use a rubber tiler's squeegee for this (like you use to put grout onto tiles). Then let it dry and remove any excess on the surface by wrapping a cloth around a circle of material, say a bit of acrylic. Wet this with the appropriate solvent then buff the surface with it. Of course you need to be careful if the engraving is not very deep as the cloth may lift some of the paint out of the engraved area. And be careful if filling acrylic this way. It can scratch, so use a very soft cloth and make sure no dust is on the surface. Alternatively, cover the material with signmaker's application tape (basically large sized low tack masking tape) prior to engraving, then spray paint once engraved. The tape acts as a mask. Then just peel the tape off once dry. I use both of these methods every day.
