3020 water connections
unravelled
Post by unravelled »
Please could someone tell me which water pipe is which on the LS320? I know the return should be cut at a slant, but I pinched a bit of that tube, (and stupidly cut it straight), as sleeving for the joint when I replaced the PSU.
So should the water inlet to the laser tube be at the left where the black wire and external mirror are, or the right where the red HT connection is?
I have tried a few searches and scans through threads but haven't found any info so far.
Re: 3020 water connections
In is on the right where the red HT lead is as far as I remember - it certainly is on the 3060 ;)
unravelled
Thank you, I will give that a try, and cut the end so that I don't forget again...
The flow goes to the red end of the tube first and out from the black end.
