Software query
mandy6840
Software query
Post by mandy6840 »
I'm a relatively new user of a 6840.
I've just come to download a file and although it went through all the stages of download fine, when it had finished 'compiling', no file showed up in the file manager window. Then when I pressed download a second time, it came up with the error message 'Motion Card Soft Dog no same'.
The file is a BMP that I have previously successfully engraved.
I've tried turning off the laser and restarting my PC but had the same result. I've checked all the connections.
Any suggestions? This is not the first time this issue has cropped up with me.
I'm running Windows 7 on a PC.
Thanks for any advice
Mandy
Re: Software query
Sometimes it is best to create a whole new file the way you did it previously. I have had one on my 6840PRO which looked perfectly fine on the screen, was used a week before successfully, but yet when ran actually caused the machine to shoot past its home point, slipping the belts quite noisily. I deleted all of the related files in the directory (.mol, .ini, .txt, and the .ecp file) and recreated it. Was fine thereafter.
Re: Software query
Hi Mandy,
Go with Phil's suggestion first, if that doesn't solve the problem I have an idea what it could be based on the error message.
mandy6840
Re: Software query
Post by mandy6840 »
Hi guys
Thanks for the suggestion - I created a brand new file but that didn't work. By then (not sure if this is related) the 'laser' on the display on the machine itself wasn't showing up.
My other half had a fiddle last night (we don't know what he did) and it came back online....and my (original) file is now successfully installed on the download window, so it will engrave, only problem is, the machine is reverting to it's original datum point now (top right) when I press either 'test' or 'start' , so it will engrave but not where I need it to / where I'm setting it to engrave from.
Any ideas? Help - I need to fulfill a customer order today!!
Mandy
mandy6840
Re: Software query
Post by mandy6840 »
I've answered my own query - within another post - the Cancel Logic Org button has reset my datum point to flying mode.
Jeez, I'm looking forward to overcoming all this troubleshooting and becoming if not an expert then at least an experienced operator! It's a big piece of kit to be responsible for alone..!
Mandy
Re: Software query
There is also an immediate check box in lasercut which either starts from where it is moved to, or uses the machine table as shown
