Help! Machine not moving on run
Posted: Sun May 04, 2014 10:20 pm
I was just running a test piece through and my machine (3020 Pro) was working fine. I stopped the piece mid way through by hitting the stop key as normal and pur in a proper piece of material. on hitting start, the laser head moves to the start position and then everything stops. the screen locks up, the laser doesn't fire and I have to switch the machine off and back on again to get get any reaction.
The machine will still datum fine when switched back on and the "test" function still traces he expected outline, so it's evidently not a physical issue (the laser will still test fire too so that's working) but I can't get any files to run. I've emptied the machines memory and started again with a new file but the same is still happening.
Anyone else had a similar issue or know what I can try to fix this?
Cam
Cam
