cutting circles
woodturningbypaul
cutting circles
Post by woodturningbypaul »
hi all
just received my machine yesterday, now its play time !!
I am trying to cut some circles for a project to play with but they are coming out with flats, now i remember the gent who setup and installed, said there was a setting equivalent to dpi and I cant remember ( should of wrote it down ), will that help make the circles round or is there a better way.
Thanks for any help
Paul
Re: cutting circles
It can be adjusted in newlydraw, I made a post somewhere about it . . . .
Re: cutting circles
Its a 6040 isn't it?
Presume the circle looks ok on screen?
I don't kniow anything about Lasercut but I'm sure Dave will be along soon ;-)
woodturningbypaul
Re: cutting circles
Hi Dave
yes its the 6040 and yes the circle looks on on screen
thanks also for philly
paul
Ellie at HPC
Re: cutting circles
Post by Ellie at HPC »
Hi Paul,
Chris was probably referring to the scan gap which is an engraving feature. A lower scan gap value will result in better quality yet slower engraving times.
Hope that helps. :D
Ellie
Re: cutting circles
Hiya Paul,
What drawing package are you using?
When you cut do you suddenly get a big flat on the circle for no apparent reason?
woodturningbypaul
Re: cutting circles
Hi Dave
sorry for the late reply got called in to do some real work !!
I was using 2d Design to trace round the circles or items with large curved area then export just playing with the machine and the software, i guess as i was tracing the line, the points were 2 far apart. When i used the circle tool they came ok. so the question is there anyway to smooth the curved sections and loose the flats
thanks again
endcan
Re: cutting circles
Post by endcan »
Hi Paul
when you export do you get an option to export as dxf ? make sure you export as curves - try to export as plt from lasercut this may work better.
Then as a test in lasercut draw the circle then dimension i.e 50 x 50mm see how this looks then you get a view for the cut shape .
hope this helps
Re: cutting circles
If you get stuck Paul, send it over and I'll mod the polys into circles or curves for you.
SimonMallas
Re: cutting circles
Post by SimonMallas »
Hi paul,
You'll just have to watch out for 2d not quite doing what you'd expect when tracing!!! Broken poly lines / I closed vectors is a good one, just import into lasercut and then Tools / Check Date. This will point out any problems..
Cheers Simon
