Ensuring only cut lines once
Posted: Mon Feb 07, 2011 7:53 am
Cutting small intricate parts I found laser would make two or more 'passes' on some lines making them wider or even burning through thin parts completely. Also takes longer to cut job with extra laser time used.
I use CorelDraw to design. Checked these files and found the obvious! When, say, you draw two rectangles and bring them together side-by-side where they join there are two lines! Laser cuts these twice. This can happen with other shapes too. Solution is to ensure you delete one of the joint lines before saving file and sending to NewlyDraw and laser. Also make sure you have lines set to 'HAIRLINE' width when drawing or laser can make two, three or more passes.
BobG
BobG
