wrong pattern being printed on ls3040
Posted: Mon Apr 06, 2020 5:35 pm
PROBLEM SOLVED, NOT SURE HOW TO DELETE THREAD
Hi, pulling my hair out today (what little's left). I use my machine mainly to cut sets of dominoes on 5mm acrylic. I have a full set pattern (4 x 7 dominoes) and to use the acrylic more efficiantly a top-set and a bottom-set. These are the top two rows of a domino pattern and the bottom two rows. Today, although I have used all the patterns in the past the top set pattern keeps trying to cut and engrave a full set. When I align the acrylic on the bed and press the test button it outlines a correct shape for two rows of dominoes. When I press start the laser positions itself further down the bed and commences to try and cut a full set.
I have deleted all previous patterns on the machine incase their was a name over lap then downloaded just the pattern for top set. This did not work, again on test it looked like it was going to cut correctly but then continued to try to cut a full set.
I have renamed the txt file generated each time you download then downloaded again after clearing all previous patterns. Once again the laser decided that this was a full set!
Any tips anyone, something stuck in that memory that just wont shift or some weird anomoly in the pattern. Very frustrating
