No power to machine
yorkshirewhittlers
No power to machine
Post by yorkshirewhittlers »
I have just cleaned my extractor fan, put my machine on to cut something then switched it off. Gone to switch it back on, and there is no power to the machine at all, like an idiot I had forgot to plug the extractor in, have I blown a fuse because I cut something without the extractor on?
Re: No power to machine
Check the RCD on the back of the machine - reset if needs be.
The extractor not being on should not trigger the trip but plugging it in may have - at worse there could be a loose wire so check the power leads.
yorkshirewhittlers
When I switch machine on light inside is coming on now but chiller unit or machine is not coming on!
Reset the big red panic button on the top of the machine ;)
yorkshirewhittlers
Hi Dave, yet again you've saved my bacon, did what you said and everything is working again. Thank you so much. Chris 😁
Heehee - been there, done that and had Chris at HPC tell me to do the same :oops:
Glad it's sorted ;)
yorkshirewhittlers
😁😁😁 Thank goodness for Chris 😁😁😁
