Bit of a long shot but are there any technical documents available for the Laserscript LS3040? Particularly around wiring?
Kim
Technical Docs for Laserscript LS3040
Re: Technical Docs for Laserscript LS3040
Hi Kim,
I have never seen any specifically for Laserscript machines. There are plenty of sites/posts about DIY lasers but I would be vary careful as components may differ.
You could just post your question and see if anyone can help
Thanks Dave!
Btw - I'm getting loads of error messages on the forum.
Lines and lines of code appearing above the forum and in each individual post.
Not sure if it's an issue with the forum or something on my end.
Example of what I can see:
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 492: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
It is also the same here - website being upgraded so should be ok soon
best
best
