head keeps smasing against the side!!!! plz help
teachermatt
Post by teachermatt »
Hi guys any help would be majorly appreciated....
I have a ls3040.
The problem I have is entirely my fault...a job had finished and I tried taking the material out whilst the laser was moving back to the start point and got it all wrong causing a jam....now when I turn themachine on or try and do datum it just vibrates against the side....
I canstill use the keypad to move the head and have immediate ticked so is still useable....but what I am using it for ideally needs to start in the same place everytime I turn the machineon...
Have I knocked of a runner??? From looking at it nothing appears to behitting the side so I dont know why it vibrates?
Please help
Matt
Re: head keeps smasing against the side!!!! plz help
It may not be hitting the switch or the switch arm got bent - with the machine off move the head back by hand and see if the switch clicks before hitting the stops. If not check the switch is firmly in place or adjust it.
It could be the runners but you would feel it if you moved the head by hand.
endcan
Post by endcan »
Hi the 3040 can rise on the wheels causing the blade that should just miss the proximity sensor to miss it .
try to touch the sensor with a metal object just to see if its working
teachermatt
Hi guys thankw for replies...i was making do but tonight things have totally gone kaput!!! It will engrave 1 or 2 letters then jump higher or lower... it is driving me mad? It messes up letters but will happily do pictures....I have had a look at the suggestions but if I am honest I don't really understand the suggestions?
Dont suppose any of you fine fellows live near york???
Matt
Bit far for me :-)
Give HPC a call - they are in Halifax.
