Align Mirror one?
Align Mirror one?
whilst testing the mirror alignment on my LS3060 - I noticed the beam directly from the tube hits the first mirror way off center.
I am not sure if the first mirror is important because it is so close to the laser source.
Should I aim for the center of the first mirror or concentrate on mirror two?
Trying to envision the effect of each turn of these locking screws is definitely better than Seduku for brain exercise lol
llamalasers
Re: Align Mirror one?
Burcot wrote:Trying to envision the effect of each turn of these locking screws is definitely better than Seduku for brain exercise lol
60W LS6840 & CW4000
started out with LS3040
You don't have to be centre of the first two mirrors
But you want to be centre ish on the third
think backwards, the screws usually PUSH the mirror away from themselves when you turn clockwise
(from somebody that just spent 3 hours realigning a 1290 !!)
I mainly wondered if the non alignment of the first mirror was going to make centering the next two impossible
It won't make it easier
If possible you need all three mirrors as close to centre as you can get
Thanks Dave
I was kind of hoping (in a masochistic way) that all the mirrors needed to be accurate
I will need to start from scratch then but - hoping it will be worth the effort
There are some minor issues with using knarl'd out beams (ie: getting them straight by the final mirror only) but it only really affects the bigger machines with full flying optics like the 1290 and 1690 where the distances involved get pretty long
It is traditional to wave your arms about and pretend that they are the laser and your body is the mirror. This helps.
No really, it does.
No really, it does.
Yep - agreed - its called the mirror alignment pilates system
Users browsing this forum: No registered users and 29 guests
