Fire :(
Re: Fire :(
I don't cut acrylic ... but I guess improved extraction (and maybe air assist) would reduce the risk ?
Take the fumes out .. then they cant ignite
Re: Fire :(
You should treat all materials the same
It's not just acrylic that gives off resigns/fumes that can ignite
Re: Fire :(
not quite true .. some are MUCH worse than others !Tom wrote:You should treat all materials the same
you'd have to try hard to ignite MDF fumes
I've spent the last hours of today with a blow torch and scraper cleaning off the MDF residue of the bed .. no fires or anything !
Re: Fire :(
Thats quite funny
Re: Fire :(
I thought so too, as I was doing it ! lol
once a year it gets a good going over
new honeycombe too ...
Re: Fire :(
Once a year that's terrible
Re: Fire :(
More air = more oxygen. Tried itLightnin wrote:I don't cut acrylic ... but I guess improved extraction (and maybe air assist) would reduce the risk ?
The acrylic is basically getting too hot and becoming more volatile at the hot spot, I doubt we would be able to increase the extraction enough to the system (I have quite a good setup already) - inert gas would be a possibility.
All materials we use in the lasers carry a risk - airborne particles become explosive even. MDF, once alight burns quite fiercely - given the right circumstances I suspect it could be as good (bad!?) as acrylic. Wood fumes are flammable - do the school experiment of heating sawdust in a test tube and ignite the fumes - think someone made an engine to work off the fumes too!
The sticky residue MDF excretes when cut in the laser (I assume the bonding agent) help to suppress a flame so the risk is lower but still present.
At the end of the day the 'never leave unattended' is the final solution
llamalasers
Re: Fire :(
Aye from now on I'm physically checking the machine every minute or so when doing a cut.. it's only a matter of standing up and looking over.
60W LS6840 & CW4000
started out with LS3040
Re: Fire :(
I have wondered about rigging up some sort of adjustable heat detector that sits in the machine - phillydee - one for you matey
TimBobTastic
Re: Fire :(
is fire a higher risk on machined with honeycomb beds that sit in a pretty much enclosed tray?
If so... could the enclosed tray be modified so it was more open allowing for a better flow of flammable gasses...
Just thinking aloud really... probably a bad idea for reasons I have not thought of... But I have access to a friendly bunch of sheet metal workers and industry standard 3D CAD... so was wondering if a little design effort could reduce the risk of fire without making big changes to the machine (apart from swapping the honeycomb tray)
Users browsing this forum: No registered users and 73 guests
