Ready To Buy a New Machine
llamalasers
Re: Ready To Buy a New Machine
Post by llamalasers »
I'm not even joking, think I'll have to take about 30mm out either side, will screw it back once it's in.
60W LS6840 & CW4000
started out with LS3040
Post by Lightnin »
check with HPC if there are any bits you can remove to get it through
llamalasers
I've chatted with them about in email and will mention it on Friday. I notice that the machine has 3 main sections but I'm not sure if dismantling/rebuilding it will be more hassle than getting busy with the jigsaw. It will be a matter of getting it here and judging it on the spot.
This is said door:
The gap with the door off is about 67cm, looking at it closely I reckon I could take both sides of the door frame off then reattach once in, bit of putty on the windows either side, jobs a gooden.
I'll take pictures for the lols.
60W LS6840 & CW4000
It will fit if you lift the top section off of the bottom by removing a few screws, 6840 will go through a std door but a 670 will be a bit narrow.
Simply remove the top half of the machine :)
llamalasers
I'm not so sure Dave, look at the side profile of the 6840:
The top section appears to me to be maybe taller than it is wide and it's 760mm wide.
I note that it may split into three smaller sections but will have to see how complicated that is?
60W LS6840 & CW4000
split above the roller cabinet, try to avoid splitting at the table level. I had to take one apart to move it for a buddy (my original 6840 was much bigger, the new models are a lot smaller)
Post by Lightnin »
how big are the windows ?
could you take a pane out and put it back after ?
llamalasers
Now I have it home and got a tape measure on it I've realised the top section is about 65cm, which means if I unattach it from the cabinet I can tip it sideways and get it through, just.
Project for the morning though, 11 hour round trip and I'm bushed.
Great to meet Chris and the team, what a top lot 8-) :ugeek:
60W LS6840 & CW4000
There are 2x 25mm box sections run front to back under the top section to locate it on the roller cabinet :)
And most of the weight is in the top
