Page 2 of 2
Re: Red Dot
Posted: Wed Nov 02, 2011 1:29 pm
by podbox
very dry....
the ones on the front obviously locate the pointer, but the one underneath? ive taken one off just to see what happens, and pointer still works fine?
mock away
podbox
Re: Red Dot
Posted: Wed Nov 02, 2011 1:35 pm
I was being serious
The 4 cap screws hold it together, the two grub screws hold the diode into its holder
Re: Red Dot
Posted: Wed Nov 02, 2011 1:42 pm
by podbox
Ok, i'll put it back on then.
Cheers!
Podbox
Re: Red Dot
Posted: Wed Nov 02, 2011 1:47 pm
by podbox
is there anyway to improve the focus of the red dots? I clean the end regularly however its always blurry and about 2/3mm wide?
it doesn't really matter (can use focus tool), its just one of those things.
Podbox.
Re: Red Dot
Posted: Wed Nov 02, 2011 3:09 pm
heya Pod,
The end of the diode has a focussing lens on it,they can be removed from their housing by undoing the grub screw then making TINY adjustments to the end of the diode (it rotates) also dont do the grub screw up too tight, it will bust the red dot. The exit hole on the housing is very small, always ensure you keep this cleaned out as well
Re: Red Dot
Posted: Wed Nov 02, 2011 3:26 pm
by podbox
cool, cheers for the advice, next time im doing some maintenance i'll have look!!!
many many thanks
Podbox.
