Red Dot
podbox
Re: Red Dot
Post by podbox »
very dry....
the ones on the front obviously locate the pointer, but the one underneath? ive taken one off just to see what happens, and pointer still works fine?
mock away ;)
podbox
happy LS6840 User.
Re: Red Dot
I was being serious :)
The 4 cap screws hold it together, the two grub screws hold the diode into its holder :)
podbox
Re: Red Dot
Post by podbox »
Ok, i'll put it back on then. :P
Cheers!
Podbox
happy LS6840 User.
podbox
Re: Red Dot
Post by podbox »
is there anyway to improve the focus of the red dots? I clean the end regularly however its always blurry and about 2/3mm wide?
it doesn't really matter (can use focus tool), its just one of those things.
Podbox.
happy LS6840 User.
Re: Red Dot
heya Pod,
The end of the diode has a focussing lens on it,they can be removed from their housing by undoing the grub screw then making TINY adjustments to the end of the diode (it rotates) also dont do the grub screw up too tight, it will bust the red dot. The exit hole on the housing is very small, always ensure you keep this cleaned out as well :)
podbox
Re: Red Dot
Post by podbox »
cool, cheers for the advice, next time im doing some maintenance i'll have look!!!
many many thanks :)
Podbox.
happy LS6840 User.
