Hi all,
As usual I have a rush job over the weekend....then I have a probem.
I am working on a job that has engraving and low power cutting, I had no problem with this before, the engraving is fine but the laser
has stopped firing when cutting, also when you press the Laser test button nothing happens.
LS6840 40w
Any ideas please
Many thanks
Bob
Rush job...problem
Rush job...problem
LS6840. Lasercut. Aspire Vectric
Re: Rush job...problem
Check the power output on the machine panel menu including 2nd level down.
Many thanks Dave, that was the problem although I’m not sure how it changed.
Bob
Bob
Easy done when adjusting the table height
