Afternoon
Does anybody know if this mini compressor is basically like the Hailea that comes with laser cutters from HPC but just a bit more powerful. Does anybody out there use one?. Thank you
Stuart
Mini Diaphragm Airbrush Compressor AS 06-1 (Oil-free)
izzysdaddy
owner of a LS1290
Re: Mini Diaphragm Airbrush Compressor AS 06-1 (Oil-free)
Similar but not the same - I tried one when I had the 3020 but with a tank. It was ok but not much better than the standard pump. You may find using it at 100% duty cycle can burn it out quicker than the Hailea which are built for the demand they get.
You are better off looking at the larger Hailea pumps or a compressor.
I use a couple of small quiet compressors from Titan which are good as I can control the air assist depending on what I'm doing
izzysdaddy
Afternoon Dave
Thanks for the information. I was also viewing the Orazio oil less compressor. Even there are a couple of Youtube videos I have not seen a positive review on this brand. Maybe best stick to a known brand of silent oil less compressor.
Stuart
Stuart
owner of a LS1290
No worries - I have had one of the Titan compressors for about 4 years and it has been brilliant. Not a lot quieter than the Hailea but at least it stops every so often!
What's the flow rate on yours Dave ?
these have 10l/M .. which doesn't seem like much ?
http://www.ebay.co.uk/itm/EX-DEMO-Model ... 2548.l4275
This is the 30l - I have a smaller one I think is 25l but much the same - 152 l.min
http://www.titanprecision.co.uk/product ... ompressor/
Cheers Dave
