LASER ALIGNMENT
Rick
LASER ALIGNMENT
Post by Rick »
I am suddenly getting very poor results cutting 3mm Birch ply sourced from HPC. I have been putting it down to poor, sinewy wood. However after wasting yet another sheet - using the settings I have used for nearly 2 years now - I wondered if the beam is off centre - even though it cuts Perspex fine.
When I make single shots onto a piece of card the first shot hits the card and then I make a second shot that is nearly 4mm apart from the first. If I continually shoot the laser I end up with quite a uniform burn, but is nearly 4mm in diameter. I suspect tis is not correct - but why does the laser shoot at two different spots without changing anything?
Any input would be well appreciated.
Rick
Re: LASER ALIGNMENT
Is the card you mentioned placed before the first mirror? What sort of pattern do you get after the 2nd mirror before entering the head?
If so - the dimension is about right as the lens focuses the beam but the double beam doesn't sound right - check be the output coupler lens on the tube, it may be damaged or the tube could be on it's way out.
Rick
Re: LASER ALIGNMENT
Post by Rick »
Thanks for that. If I place the card in front of the first mirror it is central and singular and strangely, further shots after the next mirror now seem singular as well! I haven't opened the lid on the laser for a while and am surprised how much muck is in there so will give this a clean and see how things progress (I am pretty meticulous at keeping the working area of the machine clean!)
Best regards, Rick
Rick
Re: LASER ALIGNMENT
Post by Rick »
PS Any hints at a method of cleaning the radial fan?
Re: LASER ALIGNMENT
Yes worth cleaning the mirrors and check for any cracks etc.
The extractor fan can be a bit tricky - I take it apart but would not recommend doing so unless you are used to doing similar, have a lot of time and patience!
Best way without taking apart is a long stiff brush and a vacuum!
Rick
Re: LASER ALIGNMENT
Post by Rick »
HaHa! I didn't really think there was a simpler way!
Re: LASER ALIGNMENT
:D - yep best not to get it dirty in the first place! :lol:
Rick
Re: LASER ALIGNMENT
Post by Rick »
I am now experiencing an issue that is really only apparent when cutting Perspex in that the cut is slightly bevelled - only a small amount, but when it comes to glue-welding pieces together there is only marginal contact.
It would seem obvious that the laser is not exactly square with the table, but I use a spirit level on the honeycomb and shim the ends to ensure it is level. Is there a way of testing and adjustment of the laser and if so, is it a job for am amateur please?
Best regards, Richard
Lightnin
Re: LASER ALIGNMENT
Post by Lightnin »
the laser beam focus is cone shaped, coming to a point at the focal point and then spreading out again after that.
try getting the focal point half way through the material, or use a longer focal length lens, or both
Rick
Re: LASER ALIGNMENT
Post by Rick »
Good thought. Just to clarify, if I am cutting 3mm Perspex and my focal distance is normally 73mm I should increase this to 74.5mm?
